Smart home design and ESP12e Nodes
About This Project
A Smart_home system with ESP 12E sensor and activator nodes. Which i can monitör inside outside temps, unlock entrance door, open-close central heating and enable-disable corridor pir lights. If anybody intrested i can share the codes of arduino and ESP12e nodes
What’s Connected
For central unit
Arduino uno r3
PC817 optocoupler
4 channel relay board
Ds18b20 sensor
1K resistor
4.7K resistor
9v power supply
jumper wires
For outside temp node
Nodemcu v0.9 board
Ds18b20 sensor
4.7k resistor
5v usb phone charger
micro usb cable
jumper cables
For dimmable led controller
ESP 12E
12v power supply
LM317T
220R
360R
BC327
LED strip
Triggers & Alerts
I was using 2 Pir sersors externally which triggers 12v to led strip on corridor, i connected one optocoupler to this 12v output and triggers to arduino input. If any motion detected, arduino input trigers and cayanne sends sms
Scheduling
none used
Dashboard Screenshots
Photos of the Project
central unit with 4 relay output
outside temp controller
Interesting project.
You can share codes that you used there.
I’d love to see your dimmer-
central control (Arduino + Ethernet shield)
its very simple, only cayanne ds18b20 example skecth used for temp sensor. Relay controls and signal input set from cayanne wiget
ESP12E Dimmer code
With respect of Cayenne Luminosity Example
Editor: Senol9000
This sketch sample file shows how to change the brightness on a LED
strip with a transistor from Cayenne Dashboard.
Steps:
1. In the Cayenne Dashboard add a new Custom Widget, and select Slider.
2. Select a virtual pin number.
3. Set min value to 0 and max value of 4 .
4. Set DIMM_PIN to the pin number you selected.
5. Connect the LED strip [+] --- [+ 12V supply]
LED strip [-] ---- [BC 337 Collector]
DIMM PIN --- [BC 337 Base]
[BC 337 Emitter] --- GND
Please note that BC337 can handle max 0.5A if you want to control much
power please use capable NPN transistor
6. Set DIMM_PIN to the PWM pin number you selected.
7. Set the token variable to match the Arduino token from the Dashboard.
8. Compile and upload this sketch.
9. Once the ESP12x connects to the Dashboard you can use the slider to change LED brightness.
// #define CAYENNE_DEBUG
#include "CayenneDefines.h"
#include <ESP8266WiFi.h>
#define DIMM_PIN 5  //ESP12E Pin number
#define VIRTUAL_PIN V1
char token[] = "++++++++++++";
char ssid[] = "+++++++++";
char password[] = "++++++++++";
CAYENNE_IN(VIRTUAL_PIN)
  int currentValue = getValue.asInt(); // 0 to 1023
  analogWrite(DIMM_PIN, currentValue / 4); // must be from 0 to 255
ESP12E Ds18b20 code
//#define CAYENNE_DEBUG
#include <OneWire.h>
#include "BlynkSimpleEsp8266_mod.h"
const int tmpPin = 4;     // Ds18b20 sensor pin
OneWire oneWire(tmpPin);
char token[] = "+++++++++++";
char ssid[] = "++++++++++++I";
char password[] = "++++++++++++";
  Serial.print("Setup");
   sensors.begin();
  //Run Cayenne Functions
CAYENNE_OUT(VIRTUAL_PIN)
  Cayenne.virtualWrite(VIRTUAL_PIN, sensors.getTempCByIndex(0));
Sorry for my untidy prototypes, I am new for drawing shematics. As soon as i tidy my prototypes will share detailed photos and shematics
-so, like- you can make a GPIO output do PWM? Because- I have an awesome circuit for a motor control, -driving a phat TIP120 NPN transistor. a 3 amp relay controls DC polarity (direction).
