SoftwareSerial together with Cayenne working?
Is SoftwareSerial on Arduino working together with Cayenne ?
Are there special requiremenst /limitations ?
My program is not running with SoftwareSerial included
Thanks for hints
software serial and cayenne works together.
make sure you are adding the right pin number. GPIO is not same to pin shown on esp8266.
can you post the code so we can check.
ohh my fault … I used PIN 10 … which is assigend to Ethernet …
:slight_smile: yay!
I’d like to test software serial on my UNO + 8266 + Cayenne, would you share your code?
