Soil moisture nodemcu
I just tested my hygrotrie project in the ground but I do not understand my values ​​returned by the sensor.
MY CODE
#define CAYENNE_DEBUG
#define Pin A0
#define VIRTUAL_PIN V1
//// WiFi network info.
char ssid = “”;
char wifiPassword = “”;
char username = “”;
char password = “”;
char clientID = “”;
Serial.println(“Setup”);
void loop(){
//Run Cayenne Functions
//Cayenne.run();
int x = analogRead(A0);
int y = map(x, 945, 380 , 0, 100);
Cayenne.virtualWrite(V1,y);
Serial.print(“umidade”);
Serial.println(y);
MY SERIAL CONSOLE SENSOR INTO THE GLASS WITH WATER
eau
MY SERIAL CONSOLE SENSOR INTO THE GLASS WITHOUT WATER
NO%20eau
First, try to understand your sensor without cayenne code. this gives you a better idea of the sensor and its value.
It is a resistive type sensor: the electrical resistance of the dry ground is higher than that of the wet ground
sorry, i meant try to understand your sensor by looking at the output in the serial monitor without the cayenne code.
Now all my values ​​are OK but I still have two problems
1 °) I am obliged to double my code
int x = analogRead (A0);
int y = map (x, 1023, 0, 0, 100);
for this to appear in the console and in the cayenne interface.
2 °) The data go back in cayenne I see them in data but I have no creation of Widjet.
Finally, how to mount 2 other soil moisture sensors on the one hand mounting but also in the code?
#define DHTTYPE DHT22
#define DHTPIN  4
#define Pin A0
#include <DHT.h>
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "";
char password[] = "";
char clientID[] = "";
//Variables for DHT11 values
float h, t, hif;
//Time to sleep - 10 minutes - delete a zero to set to 1 minute
int SleepTime = 60000000;
//Values sent/error booleans
bool CayenneSent = false;
bool ReadError = false;
DHT dht(DHTPIN, DHTTYPE);
  Serial.println("Setup");
  ReadError = true;
 //Only check values if there is a ReadError
  if (ReadError){
    ReadError = false;
    //Check if read failed and try until success
    int WhileLoops = 0;
    do {
      WhileLoops++;
      //We can't go too long without calling Cayenne.loop() so exit this loop after 2 seconds and set an error flag
      if (WhileLoops >= 4){
        Serial.println("Sensor Read Error");
        ReadError = true;
        break;
      //Read temperature as Celsius
      t = dht.readTemperature();
      //Read humidity (percent)
      h = dht.readHumidity();
      //Calculate Heat Index as Celsius
      hif = dht.computeHeatIndex(t, h);
      delay(500);
    } while  (isnan(t) || isnan(h));
    Serial.print("Humidity: ");
    Serial.println(h);
    Serial.print("Temperature (c): ");
    Serial.println(t);
    Serial.print("Heat Index (c): ");
    Serial.println(hif);
    //Read soil moisture
    int y = map(x, 1023, 0 , 0, 100);
    Serial.println(x);
    Serial.print("Hygrométrie ");
    Serial.println(y);
  else {
    //Check if we sent all values and sleep for 10 minutes if we did
    if (CayenneSent){
      Serial.println("Sent all values - sleeping");
      delay(100);
      ESP.deepSleep(SleepTime, WAKE_RF_DEFAULT);
      delay(100);
CAYENNE_OUT_DEFAULT()
  //Check if there was a read error and skip sending values if there is
  if (!ReadError){
    //Send Values
    Cayenne.virtualWrite(0, h, "rel_hum", "p");
    Cayenne.virtualWrite(1, t, "temp", "c");
    Cayenne.virtualWrite(2, hif, "temp", "c");
    delay(60000);
    //Set CayenneSent to true so we know when to sleep
    CayenneSent = true;
sorry but i dint understand what you trying to do. can you provide more details?
this code looks like from other topic you created and you have not answered my question.
so let’s start a fresh and keep both topic separate.
what is the problem you are facing using soil moisture?
