[solved] Not getting a Client ID for MQTT nor a token
  • NodeMCU ESP-12E
  • Android
Hey everyone, I’ve got a problem with the Dashboard at the moment. I’m having trouble connecting my device because I’m neither getting a token nor a Client ID for my app. I’ve tried to connect through both MQTT and the Cayenne own protocol (not sure what that’s is called).
Is there a problem with issuing connection data like the Client ID or the token at the moment?
Best,
Hendrik
//#define CAYENNE_DEBUG
char ssid = “ssid”;
char wifiPassword = “wifiPassword”;
char username = “MQTT_USERNAME”;
char password = “MQTT_PASSWORD”;
char clientID = “CLIENT_ID”;
unsigned long lastMillis = 0;
	lastMillis = millis();
	//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
Solved: had to delete all data of the app and re-login. Now it’s working.
@amruthrajsagar, not sure how that’s supposed to help me. But never mind, it’s solved. Thanks anyway.
