[solved] Unable to get data on Cayenne dashboard, please help
I am retrieving data from 3 adxl345 sensors connected to Arduino Uno which intern connected to ESP8266 NodeMCU (via I2C), i am getting data when i don’t connect to Cayenne but connecting to Cayenne my board is resetting.
Following is my ESP8266 code;
#include <Wire.h>
char ssid[] = “xxxxxxx”;
char wifiPassword[] = “xxxxxx”;
char username[] = “xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx”;
char password[] = “xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx”;
char clientID[] = “xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx”;
unsigned long lastMillis = 0;
int data[]={0,0,0,0,0,0,0,0,0};
int x,y,z,x2,y2,z2,x3,y3,z3;
void setup(void) {
Serial.begin(115200); /* begin serial for debug /
Wire.begin(D1, D2); /
join i2c bus with SDA=D1 and SCL=D2 of NodeMCU */
void loop(void) {
lastMillis = millis();
Wire.requestFrom(8, 15); /* request & read data of size 13 from slave */
int i=0;
while(Wire.available()){
int c = Wire.read();
data[i]=c;
i++;
x=map(data[0],0,255,-127,127);
y=map(data[1],0,255,-127,127);
z=map(data[2],0,255,-127,127);
x2=map(data[3],0,255,-127,127);
y2=map(data[4],0,255,-127,127);
z2=map(data[5],0,255,-127,127);
x3=map(data[6],0,255,-127,127);
y3=map(data[7],0,255,-127,127);
z3=map(data[8],0,255,-127,127);
Serial.print(x);
Serial.print(",");
Serial.print(y);
Serial.print(",");
Serial.print(z);
Serial.print(",");
Serial.print(x2);
Serial.print(",");
Serial.print(y2);
Serial.print(",");
Serial.print(z2);
Serial.print(",");
Serial.print(x3);
Serial.print(",");
Serial.print(y3);
Serial.print(",");
Serial.println(z3);
delay(1000);
Cayenne.virtualWrite(1, x);
Cayenne.virtualWrite(2, y);
Cayenne.virtualWrite(3, z);
Cayenne.virtualWrite(4, x2);
Cayenne.virtualWrite(5, y2);
Cayenne.virtualWrite(6, z2);
Cayenne.virtualWrite(7, x3);
Cayenne.virtualWrite(8, y3);
Cayenne.virtualWrite(9, z3);
Please help
Why do you use Cayenne.virtualWrite inside main loop, move it from there.
But still the same problem, please help
#include <Wire.h>
char wifiPassword[] = “xxxxx”;
char username[] = " ";
char password[] = " ";
char clientID[] = " ";
void setup(void) {
Wire.begin(D1, D2); / join i2c bus with SDA=D1 and SCL=D2 of NodeMCU */
void loop(void) {
int i=0;
data[i]=c;
i++;
Serial.print(x);
Serial.print(",");
Serial.print(y);
Serial.print(",");
Serial.print(z);
Serial.print(",");
Serial.print(x2);
Serial.print(",");
Serial.print(y2);
Serial.print(",");
Serial.print(z2);
Serial.print(",");
Serial.print(x3);
Serial.print(",");
Serial.print(y3);
Serial.print(",");
Serial.println(z3);
delay(10000);
CAYENNE_OUT(V0)
Cayenne.virtualWrite(V0, x);
CAYENNE_OUT(V1)
Cayenne.virtualWrite(V1, y);
CAYENNE_OUT(V2)
Cayenne.virtualWrite(V2, z);
CAYENNE_OUT(V3)
Cayenne.virtualWrite(V3, x2);
CAYENNE_OUT(V4)
Cayenne.virtualWrite(V4, y2);
CAYENNE_OUT(V5)
Cayenne.virtualWrite(V5, z2);
CAYENNE_OUT(V6)
Cayenne.virtualWrite(V6, x3);
CAYENNE_OUT(V7)
Cayenne.virtualWrite(V7, y3);
CAYENNE_OUT(V8)
Cayenne.virtualWrite(V8, z3);
@amruthrajsagar you are using MQTT so cayenne.virtualWrite is placed in main loop at an time interval interval using millis.
    //Cayenne.luxWrite(2, 700);
if i do so, i only get values one time and it gets reset . it is not uploading to cloud
i would request you to alter the following code of mine to upload data to Cayenne, it will be a great pleasure
, thank you
#include <Wire.h>
Serial.begin(9600); /* begin serial for debug /
int i=0;
data[i]=c;
i++;
//Serial.print©;
//Serial.print(",");
Serial.print(x);
Serial.print(",");
Serial.print(y);
Serial.print(",");
Serial.print(z);
Serial.print(",");
Serial.print(x2);
Serial.print(",");
Serial.print(y2);
Serial.print(",");
Serial.print(z2);
Serial.print(",");
Serial.print(x3);
Serial.print(",");
Serial.print(y3);
Serial.print(",");
Serial.println(z3);
//delay(1000);
#include &lt;Wire.h&gt;
#include &lt;CayenneMQTTESP8266.h&gt;
void setup(void) {
void loop(void) {
int i=0;
data[i]=c;
i++;
Serial.print(x);
Serial.print(",");
Serial.print(y);
Serial.print(",");
Serial.print(z);
Serial.print(",");
Serial.print(x2);
Serial.print(",");
Serial.print(y2);
Serial.print(",");
Serial.print(z2);
Serial.print(",");
Serial.print(x3);
Serial.print(",");
Serial.print(y3);
Serial.print(",");
Serial.println(z3);
[solved] 'wdt reset' by NodeMCU?
i seriously thank you a lot for your valuable reply.
I tried with the code given and i found that there is no error with the code which u gave and which i have posted. I found the problem that when i remove data jumpers from ESP8266, values will update to cloud (all values are zeros), but when i reconnect the jumper wire which receives data from sensors, it is giving as ‘wdt reset’.
I googled it but didnt work.
I want your help
Thank you
How about the following library example??.. how can i use this in my code;
#include <CayenneESP8266WiFi.h>
char token[] = “AuthenticationToken”;
char ssid[] = “NetworkSSID”;
char password[] = “NetworkPassword”;
You need to add some sleeps to your code. You should always have some delay in loops to reset the watchdog timer (unless you really do wan’t it to reset) Try this:
#include <Wire.h>
void setup(void) {
	//!!!!!!!!^^^is this supposed to be commented out?!!!!!!!!!!!!!!!
void loop(void) {
	int i=0;
		data[i]=c;
		i++;
		delay(10);
	Serial.print(x);
	Serial.print(",");
	Serial.print(y);
	Serial.print(",");
	Serial.print(z);
	Serial.print(",");
	Serial.print(x2);
	Serial.print(",");
	Serial.print(y2);
	Serial.print(",");
	Serial.print(z2);
	Serial.print(",");
	Serial.print(x3);
	Serial.print(",");
	Serial.print(y3);
	Serial.print(",");
	Serial.println(z3);
