State of button not keep (MQTT)
I’m trying to use Cayenne with MQTT, it’s working fine for displaying data, but not for button 'it’s ok also for slider and 2 states display)
if i send a 1 to the channel of my button with “light icon” the icon become yellow, but if i refresh the display the button back to grey …
from the other way it’s the same, if i click on the button, i receive 8pwIxvIJq4yFvsI,1 and the widget is waiting
so i publish 1 to my button and then the button go back to grey, before i publish ok,8pwIxvIJq4yFvsI
could you explain to me where i’m wrong
Welcome to Cayenne!
Did you send the actuator updated command? Scroll down a bit to the Send Actuator Updated Value section. http://mydevices.com/cayenne/docs/#bring-your-own-thing-api-manually-publishing-subscribing-control-a-light-actuator
Hi Adam, thanks for your answer, but yes i have followed this section, but the state ON is no keep …
By the way, i have also try the Android App, and the App said: “No device” ???
MQTT does not currently show up in the mobile app, which is why you got that error. Can you post your code so we can look it over?
