Hi, I’m here again.
This time, I connected my LinkIt Smart 7688 Duo to Cayenne, is similar to connect an Arduino Yun, but first you have to enable Bridge on the LinkIt. Cayenne has native support for Yun
Project on Community:
Hackster.io :
Connecting LinkIt Smart 7688 Duo to Cayenne - Hackster.io
Instructables:
http://www.instructables.com/id/Connecting-LinkIt-Smart-7688-Duo-to-Cayenne/
Don’t forget that in Hackster now is live the contest:
The Future of Smart Home and Office is Here!
(The Future of Smart Home and Office is Here! - Hackster.io ) using LinkIt Duo
ida
October 11, 2016, 10:37am
70
This is my third project.
It’s to connecting your TV remote to cayenne.
About This Project
We can use cayenne as remote controller for television or air conditioner.
Only one device can remote all TV/AC, more simple and can develop to other project by trigger.
Example, if we enter the room then air conditioner can ON itself and if we out the room it’s OFF automatically.
What’s Connected
Arduino MEGA 2560
Ethernet shiled W5100
IR receiver
IR transmitter
Triggers & Alerts
No triggers for now
Scheduling
No scheduling for now
Dashboard Screenshots
[image] …
LED TV Remote Controller Using Cayenne: We can use cayenne as remote controller for television or air conditioner.
Example, if we enter the room then air...
Hi again!
this time I made a awesome project, connected Particle Photon and LinkIt ONE through Cayenne for trigger a Doorbell… but… with your custom song (on mp3 format)
About This Project
The idea is simple, but the development not so much hehe. By a button on a board connected to Internet, activates the sound of a melody (whose mp3 file you have selected) in another board connected to Internet too (the Doorbell).
What’s Connected
Button on Particle Photon
Speakers on LinkIt ONE
Triggers & Alerts
[image]
Scheduling
Set and Generic Sensor Widget for Particle Photon
[image]
[image]
Flash the code through Cloud IDE
[image]
3. Add a Widget for Ge…
on Hackster.io
Remote Doorbell with Custom (mp3) Song with Cayenne - Hackster.io
on Instructables:
http://www.instructables.com/id/Remote-Doorbell-With-Custom-mp3-Song-With-Cayenne
Please after watch the demonstration video (on youtube), suscribe to my channel
Soy hacker, pero de los buenos... y te enseñaré algunos Life Hacks, Tech Hacks y similares que puedes aplicar a tu vida diaria, para hacerla más simple ;)
Todo lo que hablo de tecnología no solo lo hago desde el punto de usuario final, sino también...
This project look cool, not?
ida
October 13, 2016, 11:02am
73
This is my 4th project. I hope you like it.
About This Project
Falling down is too risky to many old man. If they are fall, we must helping them as soon as possible before any bad bad things happened. The problem is we can’t always keep watch their activities.
So, in this project we will create a prototype of fall detection to solve the problem above.
This device should send an alert to your email if fall detected.
What’s Connected
NodeMCU ESP8266
MPU6050 triple axis acc gyro
Triggers & Alerts
Trigger to send email if fall detecte…
Fall Detection of Old Man Using Cayenne: Falling down is too risky to many old man. If they are fall, we must helping them as soon as possible before any bad bad things happened. The problem is we can't always keep watch their activities.
So, in this...
Hi, this is my Third project take a look at it
About This Project
Temperature monitor can be useful to sense the room temperature of your home and based on the temperature level AC or Fan can be switched ON/OFF.We cant able to measure the temperature without any display or any instruments.No need here.Just our Phone is enough to get the Temperature Value that too Cayenne App is enough to measure.Cayenne makes it true.
Interfacing LM35 to Arduino by
Connecting the temperature sensor to board
Connect the +Vs to +5v on your Arduino board.
Hi, this time I done a project for exploid the GPS Feature of LinkIt ONE
Project in Community:
About This Project
Using the GPS functionality of LinkIt ONE, publishing latitude and longitude data to Cayenne, and see it in real time.
What’s Connected
LinkIt ONE with GPS Antenna
Photos of the Project
STEP 1: Test GPS with a Base Sketch
[image]
[image]
[image]
The Door of my house is in the star
STEP 2: Create Widgets for Virtual Analog Input
[image]
[image]
[image]
[image]
As Cayenne will not able to receive letters, we send the directions N/S E/W as values 1/0
[image]
Aju…
Hackster.io :
LinkIt ONE GPS Live Tracker with Cayenne - Hackster.io
Instructables:
http://www.instructables.com/id/LinkIt-ONE-GPS-Live-Tracker-With-Cayenne
Finished this, makes me think that Cayenne is missing a Map Widget, to display values like these, I hope you can add, or at least should have a contest to create Widgets (giving the necessary tools, I think it would create many interesting widgets)
ida
October 16, 2016, 4:05pm
77
Hi, this is my fifth project to control tv antenna with cayenne
About This Project
In this project, I will create a rotator for tv antenna, because in my area tv signal reception is very depend on antenna direction.
so I create antenna rotator using cayenne to make me easier without moving antenna directly.
What’s Connected
NodeMCU ESP-12E
Micro Servo
Triggers & Alerts
No triggers
Scheduling
No schedulling
[image]
[Antenna Rotator using Cayenne]
[image]
[image]
In this project, I will create a rotator for TV antenna, because in my area, TV signal reception is very dependent on antenna direction. By Sinchan0009.
ida:
Kewl! I like your use of Esp12-e.
Hi, this is my first project - definitely more to come as I really like this interface. It is just a simple temperature sensor - next step is to hook it up to a relay to turn on my heater!
bestes
October 17, 2016, 5:25pm
80
Hi @one21two12 ,
Can you please publish your Cayenne project on Hackster.io ? It’s currently ‘unlisted’.
Thanks!
Guys,check my first project with Cayenne.
Project link in Hackster and Instructables
pdpro
October 20, 2016, 4:43am
85
Please check the project made with Cayenne at following link:
About This Project
This project is intended to change the behavior of office employees with smart monitoring of sitting pattern. In this project, I tried to hack into my sitting pattern and make the table area smarter itself.
Cayenne interface has really helped me realize the idea in few steps. Since last few years, I used to work with Python API for SMTP which keep giving me trouble due to advanced security features of gmail. Further SMS integration was a nightmare for me.
Hackster.io link…
Project has already been submitted on Hackster and Instructables. Instructables had featured my project yesterday.
Made my second project using Cayenne! Used the Android app for this one, and I can honestly say without the services that Cayenne provides this project would have taken much much longer from start to finish. It can be improved by a lot but I am happy with the results, it works very well
Hey guys!
At last I had time to publish my first project and compete in this contest
Here are the links regarding the project and my email to apply for the participation prize. (Hope it is good enough )
Instructables has also featured the project and in 24 hours it got 1.2k views
About This Project
Hey Guys!
My name is João Duarte, I’m an IT Consultant at full time and this is my first project using cayenne
Here i’m describing how to build a box where you can plug devices, and with the aid of a Raspberry PI and Cayenne, you can control anything you like from anywhere.
Please let me know if the instructable (or my english) aren’t clear enough so I can edit it.
What’s Connected
Raspberry Pi Zero
Itead 2x Relay Module
2 European Outlet
Jumper Wires
1x Fus…
Pi Outlet Relay Control Using Cayenne: Hey Guys!
My name is João Duarte, I'm an IT Consultant at full time and this is my first instructable :D
Here i'm describing how to build a box where you can plug devices, and with the aid of a Raspberry PI and...
My email address is: joaomiguel.gduarte@gmail.com
Congratz @bestes and the rest of the team about making such a contest! The participation prize is really good so we can continue supporting our hobbies and publish our work.
