Switch sensor on and off using switch present in dashboard
I want to set up a toggle switch in dashboard in order to switch my PIR sensor ON and OFF. I mean when the PIR sensor is switched ON data should be sent to the dashboard in real time while as when the PIR sensor is switched OFF via toggle button in dashboard, it shouldn’t send any data because i dont need it on regular basis but i can’t find a way out.
add a button and use a if condition for the PIR sensor.
if(x == 1)
//PIR sensor reading.
CAYENNE_IN(1)
	int  x = getValue.asInt() ;
"expected unqualified-id before ‘if’ “.While compiling code this appears in the arduino IDE. I tried to keep it in void loop() which gives " ‘x’ was not declared in this scope” error.
int x; before void setup() and change
CAYENNE_IN(1)
place below code in void loop()
if(x == 1)
I tried, but unfortunately not working… Here is my code… please check it and make some necessary alterations…
#include <DHT.h>
#include <SimpleTimer.h>
#include <Servo.h>
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "";
char password[] = "";
char clientID[] = "";
#define EspSerial Serial1
ESP8266 wifi(&EspSerial);
#define PIR_SENSOR_PIN 5 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
#define LED_PIN 11
#define BUZZER_PIN 12
#define DHT_PIN  7
#define SMOKE_SENSOR_PIN A1
#define SOIL_SENSOR_PIN A3
#define RELAY_ACTUATOR_PIN 34
#define SERVO_ACTUATOR_PIN 4
#define PIR_VIRTUAL_CHANNEL V1
#define HUMIDITY_VIRTUAL_CHANNEL V2
#define TEMPERATURE_VIRTUAL_CHANNEL V3
#define SMOKE_VIRTUAL_CHANNEL V4
#define SOIL_VIRTUAL_CHANNEL V5
#define RELAY_VIRTUAL_CHANNEL V6
#define SERVO_VIRTUAL_CHANNEL 7
#define DHTTYPE DHT11
DHT dht(DHT_PIN, DHTTYPE);
Servo s1;
SimpleTimer timer;
int pos = 0;
int val;
  pinMode(LED_PIN, OUTPUT);      // declare LED as output
  pinMode(BUZZER_PIN, OUTPUT);
  pinMode(SMOKE_SENSOR_PIN, INPUT);
  pinMode(RELAY_ACTUATOR_PIN, OUTPUT);
  s1.attach(SERVO_ACTUATOR_PIN);
servoGo();
  delay(10);
  EspSerial.begin(115200);
  delay(10);
  timer.setInterval(5000L, transmitData);
  dht.begin();
  if (digitalRead(PIR_SENSOR_PIN) == HIGH) {            // check if the input is HIGH
    digitalWrite(LED_PIN, HIGH);  // turn LED ON
    tone(BUZZER_PIN, 4000, 60000 );
    delay(10);
      else
     digitalWrite(LED_PIN, LOW);  // turn LED ON
     tone(BUZZER_PIN, 0, 4000);
     delay(10);
    val = analogRead(SMOKE_SENSOR_PIN);// reads the value of the potentiometer (value between 0 and 1023)
    if (val >= 100){
  val = map(val, 100, 1023, 170, 0);     // scale it to use it with the servo (value between 0 and 180)
  s1.write(val);                  // sets the servo position according to the scaled value
  delay(15);
   tone(BUZZER_PIN, 4000, 30000 );
  pirSensor();
  timer.run();
void servoGo(){
   val = map(val, 100, 1023, 0, 170);     // scale it to use it with the servo (value between 0 and 180)
  delay(15);
CAYENNE_OUT_DEFAULT()
CAYENNE_IN_DEFAULT()
int previousState = -1;
int currentState = -1;
void pirSensor()
  if (currentMillis - previousMillis >= 10) {
    currentState = digitalRead(PIR_SENSOR_PIN);
      Cayenne.virtualWrite(V1, currentState, "motion", "d");
      previousState = currentState;
void transmitData(){
  Cayenne.celsiusWrite(V2, t); //virtual pin
  float h = dht.readHumidity();
  Cayenne.virtualWrite(V3, h, "rel_hum", "p"); //virtual pin
  Cayenne.virtualWrite(V4, analogRead(SMOKE_SENSOR_PIN), "analog_sensor");
  Cayenne.virtualWrite(V5, analogRead(SOIL_SENSOR_PIN), "analog_sensor");
CAYENNE_IN(V6)
  Cayenne.syncAll();
  if (getValue.asInt() == 0) {
    digitalWrite(RELAY_ACTUATOR_PIN, HIGH);
    delay(1);
  else {
    digitalWrite(RELAY_ACTUATOR_PIN, LOW);
    delay(1);
CAYENNE_IN(V7)
  if(getValue.asInt() == 1){
  val = map(val, 0, 1023, 0, 170);     // scale it to use it with the servo (value between 0 and 180)
  delay(15);
  else{
    val = map(val, 0, 1023, 170, 170);     // scale it to use it with the servo (value between 0 and 180)
  delay(15);
i cant find above code in your code.
Thank you for replying quickly… I apologize as i posted previous code…For making sure that the toggle switch on the cayenne dashboard is working , instead of sensor I tried the code on LED but LED isn’t working which means that the variable x isnt taking the value that is assigned to it in
CAYENNE_IN(1)
Here is my code:
#include <DHT.h>
#include <Servo.h>
char ssid[] = “”;
char wifiPassword[] = “”;
char username[] = “”;
char password[] = “”;
char clientID[] = “”;
#define LED_PIN 11
#define DHT_PIN 7
Servo s1;
SimpleTimer timer;
int pos = 0;
int val;
int x;
CAYENNE_IN(V8)
servoGo();
delay(10);
delay(10);
dht.begin();
if(x ==1 ){
delay(10);
else
delay(10);
if (val >= 100){
delay(15);
pirSensor();
timer.run();
void servoGo(){
delay(15);
void pirSensor()
Cayenne.virtualWrite(V1, currentState, “motion”, “d”);
Cayenne.virtualWrite(V3, h, “rel_hum”, “p”); //virtual pin
Cayenne.virtualWrite(V4, analogRead(SMOKE_SENSOR_PIN), “analog_sensor”);
Cayenne.virtualWrite(V5, analogRead(SOIL_SENSOR_PIN), “analog_sensor”);
CAYENNE_IN(V6)
Cayenne.syncAll();
delay(1);
else {
delay(1);
CAYENNE_IN(V7)
delay(15);
else{
delay(15);
your code is bit confusing.
does this work for you??
yes, flawlessly…
I really need to sort this problem out but I cant do it on my own… I have to submit my project next week.
#14
so your entire code is working? your entire code is confusing .
