Hello everyone, I need help I can from issuing of general analog sensor to a virtual pin cayenne who I can give an example
pultroppo the sensor that I have to use not in the of cayenne
the AD8232 sensor code and very simple ache or read the documentation but but anything on the code and why or executed
#include <CayenneEthernet.h>
#define VIRTUAL_PIN V1;
#define VIRTUAL_PIN 1
#define VIRTUAL_PIN1 V3
#define RELAY_DIGITAL_PIN 31
char token[] = "//////////";
float sensorValue1;
Cayenne.begin(token);
pinMode(RELAY_DIGITAL_PIN, OUTPUT);
pinMode(9, INPUT); // Setup for leads off detection LO +
pinMode(6, INPUT); // Setup for leads off detection LO -
CAYENNE_IN(VIRTUAL_PIN)
if (currentValue == 0) {
digitalWrite(RELAY_DIGITAL_PIN, HIGH);
} else {
digitalWrite(RELAY_DIGITAL_PIN, LOW);
int analogValue1 = analogRead(A0); // read the input on analog pin 0
if((digitalRead(6) == 1)||(digitalRead(9) == 1)){
Serial.println(0);
delay(500);
else
// send the value of analog input 0:
Serial.println(analogRead(A0));
delay(500);
CAYENNE_OUT(VIRTUAL_PIN1)
Cayenne.virtualWrite(VIRTUAL_PIN1, sensorValue1);
delay(500);
Solved the problem so it works, thanks for the advice
Cayenne Ethernet Example
This sketch connects to the Cayenne server using an Arduino Ethernet Shield W5100
Steps:
Set the token variable to match the Arduino token from the Dashboard.
Compile and upload this sketch.
//#define CAYENNE_DEBUG // Uncomment to show debug messages #define CAYENNE_PRINT Serial // Comment this out to disable prints and save space #include <CayenneEthernet.h> #define VIRTUAL_PIN V1;
int sensore1 = A1;
char token = “xxxxxxx”;
