The temperature trigger does not indicate the temperature
I can not set the relay on, I can not set the temperature, It only shows me the value. Temperature sensor DS18b20
for triggers you need a if and then statment. example if temperture is above 30 then turn on the relay.
but currently the trigger feature has some bug and wont work. the team is working on it and will be out soon.
OK.Thanks.I will be waiting
