Triggers that were working a 10 days ago (20 January 2018) are no longer functioning.
A new trigger (if light low, then LED on) also does not function, even though the changing light value is visible on the dashboard and the LED can be turned on and off using the dashboard.
Are others have similar problems ?
Using ESP8266 NodeMCU with Cayenne on Windows 10
