I have set up a PIR motion sensor with Raspberry Pi. I have added the sensor and set up the trigger if the motion sensor value is 1. However, I do not see the trigger working though on the dashboard I can see that motion is being detected and value is at 1. From the previous posts, I have tried the following:
- I have tested the trigger for storage and it works. For motion sensor, the trigger does not work.
- I have tested adding the sensor on Channel 17 and Channel 27. Neither of them results in trigger messages being sent.
- I have tested adding the sensor as a digital input and motion sensor. Both cases do not work.
- I see that there is a new trigger system in the pipeline. Will I not be able to access trigger for motion sensor for quite sometime?
Kindly let me know how/when this issue can be resolved.
Thank you.
