Trigger Update / Timeline?
    PiZero
    Web and Android
I am writing to see if there is any timeline or roadmap for the triggers to begin working again; I have brand new installs of a simple PiZero with a DS18b20 sensor and use it for very simple alerting based on temperature thresholds.
The triggers are not working; when setting up a trigger the step values are not even based on temp (where they used to be) and tweaking with the current setup never successfully sends out a trigger
You can adjust the value by adding in it the box provided below.
