Raspberry pi zero with PCA9685
Web
When I create a trigger dependent on a sensor that below x the turn PCA9685 channel 1 to 0 and press save the 0 value is automatically changed to 0.5 in the saved trigger. So it basically overrides my trigger with a different value when I look at that trigger in edit.
//Paul
Hmmm…
I think it look for an input like…
negative160 to negative 120,
(I use -140 to -117 on my servo motors)
…definitely not a 1 or a 0
The PCA9685 divides the “duty cycle”
12 bits sent digitally (0 to 4095)
by the time base- (usually, 1/50th of a second, or .02 sec.)
but that time base is programmable.
so, 2mS/4096= .0488mS would be your least significant bit timing…
Argh. I’m sure my numbers are incorrect…headache.
For LED control, it would be a duty cycle of 0 to 100%
I hope that helped.
It’s in the documentation:
@file PCA9685_example.ino
Arduino sample code file for PCA9685
16-channel, 12-bit PWM Fm+ I2C-bus LED controller
See PCA9685.pdf datasheet for details
@author Thomas Oppenhoff
https://github.com/TOppenhoff/PCA9685
Language: C++
License: GNU Public License
#include <Wire.h>
#include <Serial.h>
#include <PCA9685.h>
// PCA9685 with default settings
PCA9685 driver = PCA9685(0x0, PCA9685_MODE_LED_DIRECT, 800.0);
// initialize serial for debug output
// initialize TwoWire communication
Wire.begin();
// setup the PCA9685
driver.setup();
// turn all 4 LEDs fully on
Serial.println("FULL ON");
driver.getPin(PCA9685_LED0).fullOnAndWrite();
driver.getPin(PCA9685_LED1).fullOnAndWrite();
driver.getPin(PCA9685_LED2).fullOnAndWrite();
driver.getPin(PCA9685_LED3).fullOnAndWrite();
// wait for half a second
delay(500);
// turn all 4 LEDs fully off
Serial.println("FULL OFF");
driver.getPin(PCA9685_LED0).fullOffAndWrite();
driver.getPin(PCA9685_LED1).fullOffAndWrite();
driver.getPin(PCA9685_LED2).fullOffAndWrite();
driver.getPin(PCA9685_LED3).fullOffAndWrite();
delay(500);
// go through all possible 512 of 4096 possible pwm steps in the first LED
Serial.println("FADE IN LED0");
int i;
for (i = 0; i < PCA9685_MAX_VALUE; i = i + 8)
// set the pwm value of the first led
driver.getPin(PCA9685_LED0).setValueAndWrite(i);
delay(5);
Serial.println("FADE OUT LED0");
for (i = PCA9685_MAX_VALUE; i >= 0; i = i - 8)
delay(5);
// Disco Party!!
Serial.println("DISCO DISCO PARTY!");
randomSeed(analogRead(0));
for (i = 0; i < 1000; ++i)
driver.getPin(PCA9685_LED0).setValueAndWrite(random(0, 5) * 1024);
driver.getPin(PCA9685_LED1).setValueAndWrite(random(0, 5) * 1024);
driver.getPin(PCA9685_LED2).setValueAndWrite(random(0, 5) * 1024);
driver.getPin(PCA9685_LED3).setValueAndWrite(random(0, 5) * 1024);
delay(5);
