- Device & model you are using (Ex: Pi 2 Model B or Arduino Uno with W5100 ethernet shield)
Pi3 with Raspian 25/11/16 release. - What dashboard are you using? (Web, iOS, Android)
Web or IOS, both same - Please describe the bug / issue as detailed as possible. Attaching the code and any relevant screenshots would be very helpful!
I create a trigger to switch a GPIO output on/off depending on a GPIO input. If I manually switch the output by clicking the icon, it works. When I activate the input, I see it react on the dashboard and the GPIO view. However the trigger does not see the transition.
