Triggers stopped working
    rpi2
    web,android
Triggers stopped working.
last night
temp triggers and chained triggers specifically.
However events are running.
Hi @nitrogenwidget,
We had been having some stability issues with the server that runs our alerts & triggers logic, which we pushed an update for during the 1 hour of downtime today (the update has been out for about 2 hours now). Since you posted right around then, can I ask you to double check to see if they are functioning now?
It’s working now.
Thanks!
Glad to hear it. Please let us know if it acts up again, hopefully it will not with these updates!
