Triggers suddenly not working
Hi @gregxl510900 ,
It would helpful to know what device you were using. Raspberry Pi?
Unfortunately the same problem is present in my device rpi 3
triggers are not working
Yes, we are aware we will fix this when we have some time. Good news is, we are working to transition to a much more reliable triggers & alerts engine very soon…
Hey Benny, any news on this issue?
Some idea when it can be fixed?
Problems with triggers, they are not working see screenshot. Who has a solution?
I see the description “null” and also “Ran 0 times”. I have no clou whats going wrong.
I am also facing these problems with my raspberry pi 3 model B
any idea when it is going to be fixed
