Trouble with turning off a pin using millis
I used the blink without delay example to help me write this. The idea is that I would click the widget in the dashboard on then off and let the code turn the pin off after a period of time. I have my variable “oneHour” currently set to 5000. When I turn on my widget in the dashboard, the pin goes high then almost immediately goes low. I think I’m close but…
CAYENNE_IN(VIRTUAL_PIN3)
  // read the state of the switch into a local variable:
  reading = digitalRead(buttonPin);
  buttonState = reading;
  Serial.print("buttonState ");
  Serial.print(buttonState);
      if (currentValue == 1 || buttonState == 1) {
        Serial.println("1st if");
        digitalWrite(ledPin, HIGH);
        digitalWrite(relayPin, HIGH);
        count++;
        if (currentMillis - previousMillis >= oneHour){
          Serial.println("2nd if");
          if (count > preCount){
            Serial.println("3rd if");
            digitalWrite(ledPin, LOW);
            digitalWrite(relayPin, LOW);
            buttonState = 0;
            preCount = count;
i have a similar problem , i made 2 switches ( buttons ) on my dashboard and i programmed my ESP8266 E12 module but the problem is when i click on of them some times the other turns OFF i dont know why , maybe there is a bug in the website
Thanks for your reply. I dont think we are seeing the same problem. If I remove my millis counting code I can turn it on/off. My issue is that it turns on but then immediately turns back off. It happens very quickly.
Hi @modsbyus,
Try this method:
I tried the library you suggested.Still a no go. The relay turns on but doesn’t turn back off.
Heres my full program. Maybe I am just doing something stupid.
#include "CayenneDefines.h"
#include <OneWire.h>
#include "Timer.h"
#define VIRTUAL_PIN1 V1
#define VIRTUAL_PIN2 V2
#define VIRTUAL_PIN3 V3
Timer t;
const int tmpPin = D7;
const int buttonPin = D4;     // the number of the pushbutton pin
const int ledPin =  D5;      // the number of the LED pin
const int relayPin = D6; // Pin to controll relay
const int relayMon = D3;  // Loopback from relay pin output
int reading;              //variable to store button state
int buttonState;         // variable for reading the pushbutton status
OneWire oneWire(tmpPin);
char token[] = "s755pmgd4p";
char ssid[] = "obnoxious";
char password[] = "flabergast";
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  //initialize the relay pin as an output
  pinMode(relayPin, OUTPUT);
  sensors.begin();
  t.pulse(relayPin, 10 * 1000, LOW); // 10 seconds
CAYENNE_OUT(V1)
  //Cayenne.virtualWrite(VIRTUAL_PIN, sensors.getTempCByIndex(0));
  //Serial.print(VIRTUAL_PIN, sensors.getTempCByIndex(0));
  Cayenne.virtualWrite(VIRTUAL_PIN1, sensors.getTempFByIndex(0));
CAYENNE_OUT(V2)
  Cayenne.virtualWrite(VIRTUAL_PIN2, digitalRead(relayMon));
        t.update();
        buttonState = 0;
@modsbyus,
I suggest you run the following code as is to see how the timer pulse function works:
#define relayPin D6 // Pin to control relay
#include "Timer.h"
Timer t; //timer struct
  t.update();
CAYENNE_IN(V3)
   if(getValue.asInt() == 1) //only pulse when high
      t.pulse(relayPin, 1000, 1); //pin, time(milliseconds), initial state
I tried your code and it worked great. I decided to do away with the physical button. After adding back in my monitoring pin and DS18B20 temp sensor, the temp is displayed but the relayPin wont come on when I use the dashboard button.
#include "Timer.h"
Timer t;
const int tmpPin = D5;
const int ledPin =  D7;      // the number of the LED pin
const int relayMon = D3;  // Loopback from relay pin outputstatus
char token[] = "obnoxious2";
  sensors.begin();
  t.update();
CAYENNE_OUT(V1)
CAYENNE_OUT(V2)
        if (currentValue == 1) {
         t.pulse(relayPin, 3600000, 0); //pin, time(milliseconds), initial state
         t.pulse(ledPin, 3600000, 0); //pin, time(milliseconds), initial state
