Two flow meters
Hello friends . Can two flow meters be connected simultaneously to Cayenne? Someone could help me please
Hi
It should not be a problem.
What connection is used to Cayenne?
I am using the usb connection. It only worked for me with a sensor :frowning: , help pls
I’ll write you a code if you wait for tomorrow.
Yes, of course . thank you very much . :smiley:
The sensors are connected to pins 2 and 3.
Two Flow sensors.txt (2.8 KB)
Hello tad.dvor
Can you write similar code but in Python for Raspberry?
Thank you!
thank you very much :slight_smile: . … To connect more than two, should I perform the same procedure?
This sensor uses interrupts.
For Arduino UNO can have a maximum of two sensors.
For Arduino MEGA you can have more.
ok, But the code arduino is similar?
Hi
Sorry, I do not know how to program in Python.
I think that yes, but I would to try it.
I’ll try it when I have the arduino mega, thanks for the advice :slight_smile:
#14
hi tad.dvor
I modified something the code that you sent me, specifically the part where the amount of flow is counted. Can you review it please . (I express the volume in liters)
I also checked the widget counter and I have a 480ml error approximately. (To check I took a liter of water and passed it through the sensor and simultaneously checking what the “volume in liters” widget marked)
regards :slight_smile:
codetwoflowmeters.txt (3.1 KB)
#15
I will look at it.
