I’m looking to purchase the unipi addon board for a tidy solution to control and office block for a full bms solution. I’m looking to use the , 0-10v analog inputs and outputs that unipi has built in to the board along with relays and 1wire sensors etc. I just want to know if this board will be compatible with your software . If it is this well
be amazing for future projects as alternative cheap solutions for building management ,as your software is really easy and good to use
John
