Uno + ESP8266 + Cayenne
Hi
I am trying to create an IoT demo for use in schools, makerspaces etc. First my logic:
Arduino Uno - they are really common and “known”, and they have tons of pins so that I can add lots of sensors and actuators.
ESP8266 - the UNO “antenna” is made visible for explanation purposes, rather than a board that has built-in wifi.
Cayenne - desktop and mobile apps, public dashboards
I used the circuit from here: https://www.hackster.io/jeffpar0721/add-wifi-to-arduino-uno-663b9e
I am able to get the ESP to respond correctly to AT commands.
I created a project and added an UNO using esp8266 wifi.
I used the supplied sketch.
Got “‘Serial1’ was not declared in this scope”
The description in the sketch says “This example uses the Serial1 hardware serial pins available on the Mega”.
I then tried to find information on how to modify the sketch to use software serial.
I used:
#include <SoftwareSerial.h>
SoftwareSerial DebugSerial(0, 1); // RX, TX
// Set ESP8266 Serial object
#define EspSerial Serial
ESP8266 wifi(&EspSerial);
It compiles and uploads.
Serial says “ESP not responding”
Any suggestions?
Brendon
try this code and connect esp8266 to RX and TX (Serial) of Uno.
Steps:
2. Connect the ESP8266 as a shield to your Arduino. This example uses the Serial hardware serial pins available on the UNO.
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "";
char password[] = "";
char clientID[] = "";
  // Set ESP8266 baud rate
  EspSerial.begin(115200);
  delay(10);
CAYENNE_OUT_DEFAULT()
  //Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
This library is not stable with UNO and you won’t be able to use serial debugging. As a suggestion, you might want to use an Arduino mega to create this IoT demo for schools as it is can help with debugging and is stable .
WifiShield with arduino uno compiling error
Thanks for responding.
I tried your sketch. I am unable to complete the upload if the ESP8266 is connected.
The sketch compiles and starts uploading, but never completes.
If I disconnect the 3.3V from the esp, then the upload completes.
Even if the upload completes, Cayenne never sees the connected arduino, so I assume that it is not functioning.
Any ideas?
Brendon
when you upload a sketch you need to keep both RX and TX pins of UNO empty/not unconnected. once your upload is complete you need to connect the ESP8266 back to UNO. Open your serial monitor with baud rate set to 115200. This will give you AT commands with which UNO and esp8266 are communicating.
i hope you are using a proper voltage divider.
I did all the steps I opened the srial monitor and I am recieving AT commands but Cayenne page is still waiting the board
do not create multiple post on same topic.
sorry my mistake
