UNO with ESP8266 Problems
I am trying to connect to Cayenne with an UNO and ESP8266-01. The code I am using complies but I get an erroe when uploading, The code
//#define CAYENNE_DEBUG
char ssid[] = "xxxxxx";
char wifiPassword[] = "xxxxxx";
char username[] = "";
char password[] = "";
char clientID[] = "";
unsigned long lastMillis = 0;
		lastMillis = millis();
		//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
The error I get is
Archiving built core (caching) in: C:\Users\R\AppData\Local\Temp\arduino_cache_70597\core\core_esp8266_esp8266_generic_CpuFrequency_80,FlashFreq_40,FlashMode_dio,UploadSpeed_115200,FlashSize_512K64,ResetMethod_ck,Debug_Disabled,DebugLevel_None_____d3139fbfea7204bd3f0bbff37cf12d28.a
Sketch uses 240889 bytes (55%) of program storage space. Maximum is 434160 bytes.
Global variables use 33576 bytes (40%) of dynamic memory, leaving 48344 bytes for local variables. Maximum is 81920 bytes.
warning: espcomm_sync failed
@self.raymond to connect esp8266 as shield follow this: https://github.com/myDevicesIoT/Cayenne-MQTT-Arduino/blob/master/examples/Connections/ESP8266Shield/ESP8266Shield.ino
Yes that the code i ran and got the error.
I am looking for a tutorial setting up an esp8266 01 to use as a wifi connector for my Arduino Uno. It seems I am not the only one with this problem. Has anyone harness this wifi chip for an UNO. Thanks for the help
Sprinkfitter
the code you gave above is different from the code for esp8266 as shield
Thanks I will try this code. I am going to flash the esp8266 01 in hopes
this will help. I wish there was a complete detail tutorial from flashing
esp8266 to uploading data to Cayenne.with the arduino.
Any luck @self.raymond?
