will there be support for usb devices such as icse012a which is a 4 channel relay board or serial over usb thanks derek
Are you using a raspberry Pi, or Arduino? The short answer is yes it is possible now, but it’s not as simple as adding some of the currently supported Pi sensors.
I am using raspberry pi I have 3 usb relay boards I would like to use
Hey, sorry I never got back to you. I was just doing some tab cleanup and found your thread. What model relays are you using?
