I tried Olimex ESP8266-EVB and it works.
If you want to use it, you have to use Arduino IDE with installed support for ESP8266. Then you need to connect Olimex board as is desribed here. Then you upload this code:
#include "CayenneDefines.h"
char token[] = "Your token";
char ssid[] = "Your ssid";
char password[] = "Your pwd";
For uploading code you have to select board Olimex-MOD_WIFi-ESP8266 at Arduino IDE.
When you create switch for the controlling relay you have to use pin D5
