Value showing zero after a few seconds
I am using a Cayenne node in Node-red to publish sensor data from my home automation system but one of the values is always showing 0.0 after a few seconds of the real value being displayed. In the data feed I can see that the value is correct and if I click on the chart display it shows me the data correctly and no zero values. Upon exiting the chart, the value now shows correctly but after a few seconds it returns to zero and never updates again until I repeat the chart view.
In the images attached, the one that is giving this issue is the humidity reading. All of the others are fine.
Is this possibly a bug in the Cayenne system itself?
try deleting the widget and add a new widget with different channel number.
