Value to be displayed to Cayenne via Virtual PIN
Hi all,
sorry Iā€™m doing my first steps in Cayenne.
I had first success with toggling PINS on ARDUINO :wink:
BUT
I still struggling displaying a float value e.g. 8.97 to CAYENNE via a virtual PIN
I want to see the 8.97 in the widget ā€¦
can anybbody advice me which widget I have to use and the right settings
THANKS so much
@klaus.313 welcome to cayenne community.
there are two ways to connect to cayenne and send data.
first a regular connection in where you use this code to send data to cayenne and add a custom value widget on your dashboard with same virtual pin. go to add new > custom widgets > value and fill all details with virtual pin 1.
#include "CayenneDefines.h"
int x,
    int inputPin = 2;
char token[] = "";
char ssid[] = "";
char password[] = "";
CAYENNE_OUT(V1)
  Cayenne.virtualWrite(V1, 8.97);
the second is MQTT connection.
you have to go to: add new > bring your own device > and make note of mqtt username and password and client id. and add them in this code,
//#define CAYENNE_DEBUG
char ssid[] = "ssid";
unsigned long lastMillis = 0;
  x = digitalRead(inputPin);
    lastMillis = millis();
    //Cayenne.virtualWrite(0, 8.97);
    //Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
Thanks, works perfect - I found the bug
