VirtuelWrite - dosn't show same value in dashboard
Hi
I started to play with DS18B20
and added som to this void
CAYENNE_OUT(VIRTUAL_PIN)
  Cayenne.virtualWrite(VIRTUAL_PIN, sensors.getTempCByIndex(0),TEMPERATURE, FAHRENHEIT);
  // Cayenne.celsiusWrite(VIRTUAL_PIN, sensors.getTempC(OutsideTempAdd));
  Serial.print("Temp: ");
  Serial.println(sensors.getTempCByIndex(0));
  Cayenne.virtualWrite(V10, 10);
In the dashboard i get
If i use celsiusWrite V1 shows 0
after changing to virtualWrite i get
On V1 i get 75.1 degree,
on V10 i get 50.0. It dosn’t matter what setting i use in dashboard.
The serial out shows 24 degrees celsius , as expected.
Could anyone explain how this is supposed to work, and what I am missing
Try:
  Cayenne.virtualWrite(V10, sensors.getTempCByIndex(0));
On your dashboard use channel 10 to display the value.
Hi
Thank you for a rapid response
It doesn’t do the trick
V1 shows 75.1 (VIRTUAL_PIN are defined as V1)
V10 Shows 75,8
I expected it to be shown i Celcius
PS. shouldn’t Cayenne.virtualWrite(V10, 10); show as 10 on V10 ??
There was a bug from a while back that Celsius temps were getting converted to Fahrenheit even though you were sending the temp in Celsius. @rsiegel do you know if that was ever fixed?
Hi Adam
I found 2 problems
  1. Cayenne.celsiusWrite(VIRTUAL_PIN, sensors.getTempC(OutsideTempAdd)); doesn’t work
    Cayenne.virtualWrite(V1, sensors.getTempCByIndex(0)); this work
2 it is essential that this is on top in the schets, other vise it gives wrong data, and debug doesn’t work
My code aree below, if someone else would like it.
It is also OTA compliant, so it can be uploaded over the air in arduino IDE
Do you know if it is possibly to have 2 or more readings in the same Chart view??
Thanks for you help.
Some feedback to Cayenne team:
I tried to use UECIDE (another IDE for ARV like Arduino), but it seems that cayenne’s library dosn’t follow the guidelines described here https://www.arduino.cc/en/Hacking/libraryTutorial
Mostly the Libs are not in seperate folders with same name, and the keywords.txt are missing.
thats pretty anoying, I hope it will be fixed in the future.
#include <ESP8266WiFi.h>
#include <ArduinoOTA.h>
#include <CayenneDefines.h>
#include <BlynkSimpleEsp8266.h>
#include <CayenneWiFiClient.h>
#include <OneWire.h>
const int tmpPin = 13;
OneWire oneWire(tmpPin);
char token[] = "xxxxxxx";
const char* ssid = "Ullernet";
const char* password = "xxxxxxx";
  delay(5); //added by JMS
  Serial.begin(115200);
  Serial.println("Booting");
  //  showFlashInfo();
  // Port defaults to 8266
  // ArduinoOTA.setPort(8266);
  // Hostname defaults to esp8266-[ChipID]
  // ArduinoOTA.setHostname("myesp8266");
  // No authentication by default
  //  ArduinoOTA.setPassword((const char *)"Shumatic");
  ArduinoOTA.onStart([]() {
    Serial.println("Start");
  ArduinoOTA.onEnd([]() {
    Serial.println("\nEnd");
  ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
    Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
  ArduinoOTA.onError([](ota_error_t error) {
    Serial.printf("Error[%u]: ", error);
    if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
    else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
    else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
    else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
    else if (error == OTA_END_ERROR) Serial.println("End Failed");
  ArduinoOTA.begin();
  Serial.println("Ready");
  Serial.print("IP address: ");
  Serial.println(WiFi.localIP());
  ArduinoOTA.handle();
  yield(); // Do (almost) nothing -- yield to allow ESP8266 background functions
CAYENNE_OUT(V1) { // temp reading
CAYENNE_OUT(V5) { // uptime in second.
  Cayenne.virtualWrite(V5, millis() / 1000);
  Serial.println(millis() / 1000);
CAYENNE_OUT(V10) { // Just a fixed valut to see if it worked :-)
Hi @mail4jms,
Thanks for posting the code and for doing a little bit of digging.
This is not possible, yet. It has been brought up before and is on the Cayenne product roadmap :slight_smile:
@adam Was supposed to be fixed. @rob can you test when have some free time?
