Can you PM me your login / password? I want to log in and see issue on both app and web. If you want, you can edit your password by going here before sending to me.
Missing Devices on Android App - We may have found the issue with the Android app. We’ll let you know as soon as we have a fix.
Cannot Edit sensors - I have been able to duplicate this issue. We’re looking into it & let you know. Although, as a temporary fix, try refreshing the browser & you should see the settings option pop up.
Graph not auto-scaling - I can’t duplicate this issue. Are you able to zoom in/out or click & drag to pan on that graph?
Can you see if maybe after the refresh, if that solves it?
You can try a “hard refresh” by holding CTRL & click the refresh button on your browser. Or CTRL + F5.
I found the problem.
I had the sensor as a “value” and clicked the graph icon to see the autoscale graph.
But I had previously had the sensor as a “graph” on the dashboard, with graph min and max set, which were still set after I changed it back the “value”, and those min/max were now controlling the pop-up graph min and max, so it would not autoscale. Take out the min/max and the popup graph is now autoscaling.
While we are here, let me re-launch my other problem with the App - the 1 day graph. This graph on the computer shows a full 24 hours of time from 1745 → 2400 → 0 → 1745
But the same thing on the App only gives me about 9 hours from 1745 → 2400 → 0 → 0215.
So 9 hours from 24 hours ago. If I can only get 8-9 hours, I’d prefer the most recent 8 hours, not 8 hours ending 16 hours ago. Here is the 1 day graph, and a zoom-in of the start and end.
