Wemos D1 Humidity-Moisture Fan Control
In the Morning a think about the Moisture in our Bathroom.
Why buy a ready Product for 30-50 € or $. I have a DHT22 and any Fan of old PC´s.
Its simple to Coding, on Cayenne Dashboard is the Temperature, Humidity and the State of the Fan.
On the Board its just one LED to show if the Fan is working or not.
Hardware you need
1 Wemos or else with WIFI
1 DHT22 or similar
1 Fan
1 Resistor
1 LED
The Code
Blockquote
#include “DHT.h”
#define DHTPIN 5
#define DHTTYPE DHT22 // DHT 22 (AM2302), AM2321
char ssid = “i";
char wifiPassword[] = "
char username = “***";
char password[] = "";
char clientID[] = "
unsigned long lastMillis = 0;
DHT dht(DHTPIN, DHTTYPE);
dht.begin();
pinMode(4, OUTPUT);
digitalWrite(4, LOW);
delay(1000);
float h = dht.readHumidity();
Cayenne.virtualWrite(2, h, TYPE_RELATIVE_HUMIDITY, UNIT_PERCENT);
Cayenne.virtualWrite(3, t, TYPE_TEMPERATURE, UNIT_CELSIUS);
if (isnan(h) || isnan(t)) {
Serial.println(“Failed to read from DHT sensor!”);
return;
if (h > 45.00) (digitalWrite(4, HIGH)), Cayenne.virtualWrite(1, 1, “digital_sensor”, “d”);
else (digitalWrite(4, LOW)), Cayenne.virtualWrite(1, 0, "digital_sensor", "d");
// show in serial monitor
Serial.print(“Humidity: “);
Serial.print(h);
Serial.print(” %\t”);
Serial.print(“Temperature: “);
Serial.print(t);
Serial.print(” *C \n”);
delay(500);
I honestly hope each and every one of you have the best year ever in New Year :sparkler::fireworks::earth_africa:
A good project for the new year! Thanks for sharing @Sven. We all love seeing these.
~Benny
Nice project!
