Wemos D1 mini LED-Strip Slider-Button SmartHome
Slider to control Led-brightness
I bought some LED-Stripes with 3 Volt. And thought about it to control it with Cayenne.
The Slider-Button is a great function to control the brightness.
I will build the Stripe under a shelf in the kitchen. But this later…
(general introduction, overall experience with Cayenne, why did you create this project??)
You need,
1 Wemos or similar with Wifi
1 Led-Stripe 3 Volt
06
The Code
char ssid[] = "********";
char wifiPassword[] = "*******";
char username[] = "********";
char password[] = "********";
char clientID[] = "************";
unsigned long lastMillis = 0;
CAYENNE_IN(1)
  int value = getValue.asInt(); // 0 to 255
  CAYENNE_LOG("Channel %d, pin %d, value %d", 1, 5, value);
  // Write the value received to the PWM pin. analogWrite accepts a value from 0 to 255.
  analogWrite(5, value);
CAYENNE_IN_DEFAULT()
Much Fun its a cheap SmartHome solution…
Nice project!
Great stuff! We shared this on our Twitter page. :slight_smile: https://twitter.com/CayenneIoT/status/958789792778543104
WOW, thanks to Cayenne. I will do my best to post some great builds more…
Looking forward to seeing your future Cayenne projects!
