Wemos D1 mini & Wemos DHT shield
Hello, I try to setup my Wemos D1 mini with a Wemos DHT shield (temp/hum). Is there a sample project with these components? I am a little bit lost with all that different libraries for all that different sensors.
It get it working with Wemos D1 mini and a DS18B20, at least.
Greetings
first connect your wemos using this Adding a New Device using MQTT
and for DSB18B20 Converting Cayenne Arduino LIbrary sketches to Cayenne MQTT Arduino - #2 by rsiegel
Thank you.
But that is already working. Withe the DSB18B20.
I donā€™t get it working with the Wemos DHT shield.
can you post the code.
This works for the DSB18B20.
But how can I address the DHT12 shield?
I have to include the #include <WEMOS_DHT12.h> library.
But I donā€™t now how to read the values and send it to cayenne.
//#define CAYENNE_DEBUG
#include <OneWire.h>
#define ONE_WIRE_BUS D4
char ssid = ā€œ";
char wifiPassword[] = "
**ā€;
char username = ā€œ*";
char password[] = "
ā€;
char clientID = ā€œ***********ā€;
unsigned long lastMillis = 0;
sensors.begin();
CAYENNE_OUT_DEFAULT()
Cayenne.celsiusWrite(1, sensors.getTempCByIndex(0));
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
CAYENNE_LOG(ā€œChannel %u, value %sā€, request.channel, getValue.asString());
//Process message here. If there is an error set an error message using getValue.setError(), e.g getValue.setError(ā€œError messageā€);
Hello, any ideas?
i have not worked with this shield and if you have any documentation about it we can try to solve the problem.
If you have the time, it would be cool to have a look here:
Are you able to get reading from the shield?
No. Sorry.
I tried a more easy setup.
Raspberry Pi 3 and the shield, but I donā€™t get it running.
try with wemos. it should work.
Hello Shramik, I used the WEMOS sketch and it works. I can read the values in the serial output.
DHT12 dht12;
Serial.begin(115200);
if(dht12.get()==0){
Serial.print("Temperature in Celsius : ");
Serial.println(dht12.cTemp);
Serial.print("Temperature in Fahrenheit : ");
Serial.println(dht12.fTemp);
Serial.print("Relative Humidity : ");
Serial.println(dht12.humidity);
Serial.println();
delay(1000);
But how can I pass the variables to Cayenne?
Greetings
I used this:
Cayenne.celsiusWrite(1, dht12.cTemp);
Cayenne.virtualWrite(2, dht12.fTemp);
Cayenne.virtualWrite(3, dht12.humidity);
and it is working!
Thank you.
