This works for the DSB18B20.
But how can I address the DHT12 shield?
I have to include the #include <WEMOS_DHT12.h> library.
But I don’t now how to read the values and send it to cayenne.
//#define CAYENNE_DEBUG
#define CAYENNE_PRINT Serial
#include <CayenneMQTTESP8266.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS D4
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
// WiFi network info.
char ssid = “";
char wifiPassword[] = "**”;
// Cayenne authentication info. This should be obtained from the Cayenne Dashboard.
char username = “*";
char password[] = "”;
char clientID = “***********”;
unsigned long lastMillis = 0;
Cayenne.begin(username, password, clientID, ssid, wifiPassword);
sensors.begin();
// Default function for sending sensor data at intervals to Cayenne.
// You can also use functions for specific channels, e.g CAYENNE_OUT(1) for sending channel 1 data.
CAYENNE_OUT_DEFAULT()
sensors.requestTemperatures();
// Write data to Cayenne here. This example just sends the current uptime in milliseconds on virtual channel 0.
//Cayenne.virtualWrite(0, millis());
// Some examples of other functions you can use to send data.
Cayenne.celsiusWrite(1, sensors.getTempCByIndex(0));
//Cayenne.luxWrite(2, 700);
//Cayenne.virtualWrite(3, 50, TYPE_PROXIMITY, UNIT_CENTIMETER);
// Default function for processing actuator commands from the Cayenne Dashboard.
// You can also use functions for specific channels, e.g CAYENNE_IN(1) for channel 1 commands.
CAYENNE_IN_DEFAULT()
CAYENNE_LOG(“Channel %u, value %s”, request.channel, getValue.asString());
//Process message here. If there is an error set an error message using getValue.setError(), e.g getValue.setError(“Error message”);
