Wemos D1+ MQTT pwm fan speed
I need a help.
I would liek to control 2 fan with PWM output, but it doesnt work. When i was create the MQTT version of code, then all virtual channel added automaticly, but the the slider doesnt. I want to create PWM Output widget, but it cant put to the project, just the old Arudino device.
I try to put slider,i can add it, but it doesn work.
Here is my code: link
HI, try to change value of the Slide from 0 to 1023 (instead of 0->255)
Sometime you must change channel of the virtual pin to working good.
try this code. add a custom slider widget with channel 1 selected.
#define CAYENNE_DEBUG
char ssid[] = "ssid";
unsigned long lastMillis = 0;
 #define PWM_DIGITAL_PIN1 D6
		lastMillis = millis();
CAYENNE_IN(1)
  int x = getValue.asInt();
  Serial.println(x);
 analogWrite(PWM_DIGITAL_PIN1,  x);
If i change, then how can i manage the slider from0% (off) to 100% speed?
Thanks, i will try it
in this need just a chanel number or VIRTUAL_PIN10?
yes only channel number.
thanks
do you want only two set points(stop and full speed) ??
No, i want use it between 0-100% like as a dimmer
In the code, dont need to set the dutty cycle or others?
change the slider setting and make slider minimum value to 0 and maximum to 100 and then use a map function.
CAYENNE_IN(1)
Serial.println(x);
x= map(x, 0, 100, 0, 255);
okay, i will try it
#14
Can i rename the “x”? in my code this is value or currentvalue both of 2 slider
#15
yes you can to whatever you want. its just that i love “x”:stuck_out_tongue_winking_eye:
#16
:smiley:
#17
It doesnt need?
pinMode(PWM_DIGITAL_PIN1, OUTPUT);
pinMode(PWM_DIGITAL_PIN2, OUTPUT);
#18
it doesnt work :frowning:
Maybe the phisical connection wrong?
#19
have you test this ? 0-> 1023 in your cayenne Slide widget
#20
in the code
