Whenever I Connect LCD .... Cayenne Dashboard Shows Offline
My Project is water level detection using ultrasonic sensor and arduino uno … Everything works fine but when I include “LiquidCrystal lcd (12, 11, 5, 4, 3, 2 )” , Cayenne Shows “Offline” …
This is the code that i have uploaded:
#include <LiquidCrystal.h>
#define CAYENNE_DEBUG       // Uncomment to show debug messages
#include <SoftwareSerial.h>
#include "Ultrasonic.h"
#include<LiquidCrystal.h>
char ssid[] = "AndroidAP";
char wifiPassword[] = "12345678";
char username[] = "";
char password[] = "";
char clientID[] = "";
#define EspSerial Serial
#define RELAY_VIRTUAL_CHANNEL 1
#define RELAY_ACTUATOR_PIN 7
#define VIRTUAL_CHANNEL 2
#define BUZZER_PIN 9
ESP8266 wifi(&EspSerial);
Ultrasonic ultrasonic(A0,A1);
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
lcd.begin(16, 2);
  delay(100);
pinMode(RELAY_ACTUATOR_PIN, OUTPUT);
  // Set ESP8266 baud rate
  EspSerial.begin(115200);
  delay(100);
  int  distance = ultrasonic.Ranging(CM);
   if (distance < 5 ){
 tone (BUZZER_PIN , 2000, 10000);
    lcd.setCursor(0,0);
  lcd.print("16x2 LCD MODULE");
  lcd.setCursor(2,1);
  lcd.print("HELLO WORLD");
CAYENNE_OUT_DEFAULT()
CAYENNE_IN_DEFAULT()
CAYENNE_IN(RELAY_VIRTUAL_CHANNEL)
  if (getValue.asInt() == 0) {
    digitalWrite(RELAY_ACTUATOR_PIN, HIGH);
  else {
    digitalWrite(RELAY_ACTUATOR_PIN, LOW);
CAYENNE_OUT(VIRTUAL_CHANNEL)
  Cayenne.virtualWrite(VIRTUAL_CHANNEL,distance );
  delay(1000);
are you using arduino UNO and esp8266?
Yes…
with uno this library is less stable. Do you have a arduino mega? with mega we can also print out the error which is causing the disconnect.
No I dont have mega board … Is there any alternative for achieving this
Try this code.
lcd.begin(16, 2);
  //Serial.begin(9600);
  delay(100);
  delay(100);
   if (distance < 5 ){
    lcd.setCursor(0,0);
  lcd.setCursor(2,1);
  else {
  delay(1000);
The LCD library shouldn’t cause you issues if your sketch is compiling.
Can you try physically disconnecting the LCD and see if you still show Cayenne online?
I’m wondering if you are driving into a mis-wired LCD and causing the Arduino to die.
Kreggly
I tried shramiksalgaonkar, what you told me to do… But Same issue is occuring again.
kreggly, I tried that but unfortunately nothing happens … When I introduce “LiquidCrystal lcd (12, 11, 5, 4, 3, 2 )” in my code … Arduino connects with cayenne but after 5 seconds it disconnects and shows offline …
Are you getting errors in your serial output?
No , I am not getting any error in serial
it looks like it LCD is causing some problem with esp8266 when used on arduino uno. I tested it with arduino mega and it works fine. What i will suggest buy a arduino mega and start your project with it. i am working on trying to figure out the cause with arduino uno.
Try this code:
Steps:
2. Connect the ESP8266 as a shield to your Arduino. This example uses the Serial hardware serial pins available on the UNO.
const int rs = 9, en = 8, d4 = 6, d5 = 5, d6 = 4, d7 = 3;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
char ssid[] = "";
char wifiPassword[] = "";
  delay(10);
  delay(10);
  lcd.begin(16, 2);
    lcd.print(" Cayenne!");
  //Cayenne.luxWrite(2, 700);
