Not Sure where to post this apologies if its in the Wrong category
Using Raspberry PI , i wnted to undertand the process when Cayenne Delivers a Update/Upgrade on new versions
So Obviously the “cloud” component/Dashboard is of no consequence to the Raspberry PI , However how do i update the Raspberry PI “connector” ?? or is there a “auto-Update” mecanism ?
Yep, Cayenne will just automagically upgrade when then there is an update. You can check the version in the dashboard - click on setting>configure>Agent Version. You can compare that to the release notes here Cayenne Release Notes - myDevices Cayenne Community If they ever do not match you can re-run the setup script to reinstall the agent.
