Why i Can´t create a widget
I start using the Cayenne API´s with my python scrips and a raspberrypi , i actually get conection with mqtt pythons’s library but when i create the widget (it doesn’t metter which one of the options i select) the button of add widget never is habilitated, i fill all the fields, i dont know if i forget someting, help please :s
title|690x387
Would it be possible to share the code you’re using?
Also, maybe some screenshots of what you’re seeing as well.
Then we can look into the issue you’re experiencing.
Thanks.
-Jesse
I’m seeing the same thing. And my code was working. I’ve not made any changes to it.
What exactly are you seeing? Your device is not online in Cayenne or you can’t add widgets? Screenshots help.
~Benny
Sorry, i got a connection with MQTT this is the code that i use to get connected:
import cayenne.client #Cayenne MQTT Client
from time import sleep
import serial
from gpiozero import Button
button=Button(2) # Declaring button pin 2
MQTT_USERNAME = “"
MQTT_PASSWORD = "
MQTT_CLIENT_ID = "
def send_on():
client.virtualWrite(3, 1) #Publish “1” to Cayenne MQTT Broker Channel 3
print(“Button pressed\n”)
def send_off():
client.virtualWrite(3, 0) #Publish “0” to Cayenne MQTT Broker Channel 3
print(“Button released\n”)
button.when_pressed=send_on #When button pressed run send_on function
button.when_released=send_off #When button released run send_off function
while True:
client.loop()
(note: i dont put in the post the MTTQ username and pasword but in python i do)
I want to see the state of a push button in a 2 state widget and when i get conected to the mqtt this happen
before that i run the code:
after i run the code i get this on the consol from my rpi
after all of that i cant press the add widget button to can send data
