- Raspberry Pi 3
- iOS & Web
When viewing Analog Sensors (Soil Moisure) the iOS the sensor value, needle value, nor range colors display correct values as the web version shows. (see screenshots)
The iOS version allows a Min/Max option, that the web version doesn’t but doesn’t allow for adding ranges…?
a) A nice to have in addition to the ranges so one could flip a 10-bit value into a percentage
b) Ranges then could be based on a percentage instead of hard values
