Widget not adding on iOS
    Rpi 3 mod b
    Web iOS
@bestes
When adding a widget in iOS a message comes up saying not added be sure to fill in all blanks etc. But, the widget does show up on the web dashboard.
Example: tsl2561 won’t add on iOS but showed up on web.
One time I added an analog volt widget pressed 6 times to add widget and ended up getting 6 widgets on the web dashboard.
Also as a side note your tutorial button does not take you to the correct device and today its frozen. It usually zips to the top page after loading what might be another device.
looking into the tutorial issue now!
