Wifi connectivity issue
Hello all
am trying to connect a Fishino (Arduino uno with RTC and wifi onboard) to Cayenne without success. I would like to skip the Cayenne code handling the wifi setup (am doing it manually in the sketch) and just open the connectivity but failed.
I have commented some checks in file CayenneMQTTWifiClient.h but getting this error
“Network connect failed”
any hints?
thanks and regards
You can use a standard MQTT library like pubsubclient and follow this data format https://mydevices.com/cayenne/docs_stage/cayenne-mqtt-api/#cayenne-mqtt-api-manually-publishing-subscribing
Have you try to connect your Fishino to Wifi network , with simple Example code like scanNetwork (without Cayenne ) ?
without Cayenne it works properly
