WifiShield with arduino uno compiling error
#104
@rsiegel thanks for informing us about this method, I have used it to connect Arduino Uno with ESP8266-01 to Cayenne using Software serial and it works.
#105
Hi there,
I successfully connected Arduino UNO to 8266 and Cayenne, but even though the connection is stable, data transmission happens every 15 seconds or so (the NodeMCU8266 I have instead tracks data every second on Cayenne with the same sketch and different library).
I tried both with the MQTT library and the old “CayenneESP8266Shield” custom library, same behaviour.
I’m thinking on:
  • hardware bad configuration
  • Or it’s normal to have data refreshed every 15 seconds since I have a UNO and not a MEGA, so just 1 serial port that goes in conflict with something?
Sketch:
#include <DHT.h>
#define DHT22_PIN 2
#define DHTTYPE DHT22
#define EspSerial Serial
char ssid[] = "1";
char wifiPassword[] = "2";
char username[] = "x";
char password[] = "y";
char clientID[] = "z";
ESP8266 wifi(&EspSerial);
DHT dht(DHT22_PIN, DHTTYPE);
float humidity, temp_c;
 // Serial.begin(9600);
  //delay(10);
  // Set ESP8266 baud rate
  EspSerial.begin(115200);
  delay(10);
CAYENNE_OUT_DEFAULT()
    // MOISTURE SENSOR
    int     x = analogRead(A0);
    int   y = map(x, 669, 343 , 0, 100);
    Cayenne.virtualWrite(V1,y);
    // DHT 22
humidity = dht.readHumidity();          // Read humidity (percent)
temp_c = dht.readTemperature();     // Read temperature as Farenheight
Cayenne.virtualWrite(V2, temp_c);
Cayenne.virtualWrite(V3, humidity);
#106
I think 15 seconds is a pretty reasonable refresh rate for data. Is there a reason you want it faster?
#107
Thanks for the reply, just missed it :slight_smile:
Mainly three:
  1. I’m creating a water supply system, but the water flow I’m managing should be started/stopped (and monitored meanwhile) in maximum 5/7 seconds
  2. I will increase my system to a domotic one, and I want everything to be perfectly working on a centralyzed system like Cayenne - many other applications on different systems I have are real time controlled, I don’t want to regress
  3. It perfectly works on MCU, so if I can, I do :slight_smile: :nerd_face:
As an update, I bought a MEGA, and used a logic level converter to connect esp, but… exact same behaviour. This drives me to think on a library or server issue…
Your opinion?
Thanks!
Ps in the former code I missed the if condition on millis(), but even updating it, same behaviour. It starts to be stable after setting data refresh to 20 seconds
#108
I’m having the same problem just getting the same Serial Monitor output without Cayenne seeing the UNO after successfully downloading suppaman78’s code in the post below of 1 Dec 2017.
Has anyone ever been able to follow up on finding a flashing program and more specifically the required .BIN file to overcome? Let’s keen this subject alive…
#109
Specifically how did you change your code to include the ‘on millis()’ Thanks
#110
Following up on my previous post of today, I’ve now followed the procedure in the following link and reflashed several ESP8266-01 which result in AT Version: 1.3.0.0 of July 16 2016 and SDK Version: 2.0.0.
In addition I’ve confirmed that I’ve correctly downloaded / installed libraries is suggested above being:
CayenneESP8266Shield and ESP8266HardwareSerial
Unfortunately the problem remains having Cayenne recognize the UNO via the ESP8266-01.
Any further help or successful examples are appreciated.
#111
What are you getting in the serial monitor?
#112
Here you go, just add after Cayenne.loop() :
lastMillis = millis();
Overall, be sure to use CayenneMQTTESP8266Shield library, Cayenne is switching everything on MQTT.
I now moved my installation on the MCU since I couldn’t solve the low refresh rate bug, but at least knowing that someone has a MQTT Arduino UNO/MEGA setup refreshing every second would confirm me that I should work on my hardware setup…
#113
SUCCESS AT LAST…
I eventually tracked the cause of Cayenne not recognizing the UNO through the ESP01 as being caused by poor connections from the ESP through a pin adapter and into a protoboard upon which most connections are made.
A couple of points that may help others are:
** The UNO 3.3V supply was sufficient although I tried a external 3.3V supply. External higher capacity 3.3V supply would still be recommended for a permanent installation.
** Although it is not clear on the various Youtubes etc the UNO Tx should always be connected to the ESP Tx through a voltage divider. The ESP Rx output being a lower voltage can connect direct to the UNO Rx as is the situation when you use the AT commands. Young players like me might have considered that Tx should connect to Rx in both directions but this is not correct.
** an excellent explanation of how to connect UNO to Cayenne through ESP is available at: https://www.youtube.com/watch?v=n34YOU6drEw&t=180s follow it carefully especially in my case when I used AT+CWJAP=“router-name”,“password” where I discover I was not connecting and getting a response of ‘WiFi Connected’ followed by ‘WiFi Got I.P.’
My reason for wanting to use a UNO (of which I have several spares) instead of a ESP8266-12E is that the UNO has more analogs for my application.
Thanks to all those who responded to my initial problem.
#114
Thanks for posting your solution, really helps out the community!
#115
scusate, purtroppo il mio arduino co esp01 continua a nn accettare lo sketch…sto utilizzando il traduttore per capirci qualcosa…però non capisco la soluzione… qualcuno puo aiutarmi?
