Writing temperature to a virtual pin stops upload to arduino
Hi Cayenne Community,
I am using arduino since quite some time sucessfully and tried today first time Cayenne. I have following HW setup:
Arduino Uno + Ethernetshile 1.1 (with ENC28J60)
Digital pin 2 connects with a pull-up to a DS18B20
I was using following sketch:
    #include
    #include
    #include
    #include
    #include
    #define VIRTUAL_PIN V1
    const int tmpPin = 2;
    OneWire oneWire(tmpPin);
    char token[] = "yourtoken";
      Cayenne.begin(token);
      sensors.begin();
    CAYENNE_OUT(VIRTUAL_PIN)
      Cayenne.celsiusWrite(VIRTUAL_PIN, sensors.getTempCByIndex(0));
      // Cayenne.fahrenheitWrite(VIRTUAL_PIN, sensors.getTempFByIndex(0));
It stops during upload with the very unspecific message that there was an error during upload of the sketch.
When I comment out the following line:
The upload works. Of course I don’t get any data, but there is a connection of the device visible.
Any idea where the cause could be?
Hi @martin1, I know you mentioned it was unspecific, but do you mind sharing the exact error message output (a screenshot is fine) in case it does provide a hint to exactly what’s going on here?
Hi rsiegel,
sure, I try to be es precise as possible… might be much content… :slight_smile:
this is the the error message I get… I hope my language setting is not a big problem… :laughing:
This is the error message I see, when the Virtuel Pin is used:
These are all the warnings I get then:
WARNUNG: Kategorie ‘’ in der Bibliothek UIPEthernet ist ungültig und wird auf ‘Uncategorized’ festgelegt
In file included from C:\Program Files (x86)\Arduino\libraries\arduino_uip-master/UIPEthernet.h:33:0,
             from D:\Eigene Dateien\Documents\Arduino\libraries\Cayenne/BlynkSimpleUIPEthernet.h:19,
             from D:\Eigene Dateien\Documents\Arduino\Test-Cayenne1\Test-Cayenne1.ino:4:
C:\Program Files (x86)\Arduino\libraries\arduino_uip-master/UIPClient.h:25:2: warning: #import is a deprecated GCC extension [-Wdeprecated]
#import “Client.h”
C:\Program Files (x86)\Arduino\libraries\arduino_uip-master/UIPClient.h:26:2: warning: #import is a deprecated GCC extension [-Wdeprecated]
#import “utility/mempool.h”
C:\Program Files (x86)\Arduino\libraries\arduino_uip-master/UIPClient.h:29:4: warning: #import is a deprecated GCC extension [-Wdeprecated]
#import “utility/uip.h”
In file included from C:\Program Files (x86)\Arduino\libraries\arduino_uip-master/UIPEthernet.h:34:0,
C:\Program Files (x86)\Arduino\libraries\arduino_uip-master/UIPServer.h:23:2: warning: #import is a deprecated GCC extension [-Wdeprecated]
#import “Server.h”
C:\Program Files (x86)\Arduino\libraries\arduino_uip-master/UIPServer.h:24:2: warning: #import is a deprecated GCC extension [-Wdeprecated]
#import “UIPClient.h”
In file included from D:\Eigene Dateien\Documents\Arduino\libraries\Cayenne/Blynk/BlynkApi.h:18:0,
             from D:\Eigene Dateien\Documents\Arduino\libraries\Cayenne/BlynkApiArduino.h:14,
             from D:\Eigene Dateien\Documents\Arduino\libraries\Cayenne/Adapters/BlynkEthernet.h:18,
             from D:\Eigene Dateien\Documents\Arduino\libraries\Cayenne/BlynkSimpleUIPEthernet.h:20,
D:\Eigene Dateien\Documents\Arduino\libraries\Cayenne/Blynk/BlynkProtocolDefs.h:93:0: warning: “ntohs” redefined
     #define ntohs(x) htons(x)
In file included from C:\Program Files (x86)\Arduino\libraries\arduino_uip-master/UIPUdp.h:28:0,
             from C:\Program Files (x86)\Arduino\libraries\arduino_uip-master/Dhcp.h:7,
             from C:\Program Files (x86)\Arduino\libraries\arduino_uip-master/UIPEthernet.h:30,
C:\Program Files (x86)\Arduino\libraries\arduino_uip-master/utility/uip.h:1087:0: note: this is the location of the previous definition
#define ntohs htons
Der Sketch verwendet 29.608 Bytes (91%) des Programmspeicherplatzes. Das Maximum sind 32.256 Bytes.
Globale Variablen verwenden 1.398 Bytes (68%) des dynamischen Speichers, 650 Bytes für lokale Variablen verbleiben. Das Maximum sind 2.048 Bytes.
Beim Hochladen des Sketches ist ein Fehler aufgetreten
When I comment the line out the warnings are almost identical except the last lines:
Der Sketch verwendet 25.412 Bytes (78%) des Programmspeicherplatzes. Das Maximum sind 32.256 Bytes.
Globale Variablen verwenden 1.380 Bytes (67%) des dynamischen Speichers, 668 Bytes für lokale Variablen verbleiben. Das Maximum sind 2.048 Bytes.
Any ideas what could cause that?
best regards,
Martin
