login as: pi
pi@192.168.1.43’s password:
Linux RaspberryPiZeroW-02 4.19.42+ #1219 Tue May 14 21:16:38 BST 2019 armv6l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sun Jul 7 12:05:54 2019 from 192.168.1.11
pi@RaspberryPiZeroW-02:~ $ tailtail
-bash: tailtail: command not found
^Z
[1]+ Stopped tail
pi@RaspberryPiZeroW-02:~ $ tail -f /var/log/myDevices/cayenne.log
2019-07-10 11:06:22 - myDevices - INFO - Sensors info: [{‘channel’: ‘dev:HDJKu9G5nv0DxuM’, ‘value’: -1, ‘type’: ‘digital_actuator’, ‘name’: ‘Relay Switch’, ‘unit’: ‘d’}]
2019-07-10 11:06:24 - myDevices - INFO - Send changed data: [{‘sys:cpu;load’: 3.0}, {‘sys:ram;usage’: 243597312}]
2019-07-10 11:06:37 - myDevices - INFO - Sensors info: [{‘channel’: ‘dev:HDJKu9G5nv0DxuM’, ‘value’: -1, ‘type’: ‘digital_actuator’, ‘name’: ‘Relay Switch’, ‘unit’: ‘d’}]
2019-07-10 11:06:37 - myDevices - INFO - Checking for updates…
2019-07-10 11:06:40 - myDevices - INFO - Send changed data: [{‘sys:cpu;load’: 31.0}, {‘sys:ram;usage’: 243445760}]
2019-07-10 11:06:52 - myDevices - INFO - Sensors info: [{‘channel’: ‘dev:HDJKu9G5nv0DxuM’, ‘value’: -1, ‘type’: ‘digital_actuator’, ‘name’: ‘Relay Switch’, ‘unit’: ‘d’}]
2019-07-10 11:06:54 - myDevices - INFO - Send changed data: [{‘sys:cpu;load’: 17.6}, {‘sys:cpu;temp’: 41.16}, {‘sys:ram;usage’: 241795072}, {‘sys:storage:/;usage’: 5309976576}]
2019-07-10 11:07:07 - myDevices - INFO - Sensors info: [{‘channel’: ‘dev:HDJKu9G5nv0DxuM’, ‘value’: -1, ‘type’: ‘digital_actuator’, ‘name’: ‘Relay Switch’, ‘unit’: ‘d’}]
2019-07-10 11:07:09 - myDevices - INFO - Send changed data: [{‘sys:cpu;load’: 0.0}, {‘sys:cpu;temp’: 40.622}, {‘sys:ram;usage’: 241909760}, {‘sys:storage:/;usage’: 5309976576}, {‘sys:net;ip’: ‘192.168.1.43’}, {‘sys:net;speedtest’: 2.3004317910471794}, {‘dev:HDJKu9G5nv0DxuM’: -1}] + sys:gpio
2019-07-10 11:07:22 - myDevices - INFO - Sensors info: [{‘channel’: ‘dev:HDJKu9G5nv0DxuM’, ‘value’: -1, ‘type’: ‘digital_actuator’, ‘name’: ‘Relay Switch’, ‘unit’: ‘d’}]
2019-07-10 11:07:24 - myDevices - INFO - Send changed data: [{‘sys:cpu;load’: 1.0}, {‘sys:cpu;temp’: 40.084}, {‘sys:ram;usage’: 241897472}, {‘sys:storage:/;usage’: 5309980672}]
2019-07-10 11:07:37 - myDevices - INFO - Sensors info: [{‘channel’: ‘dev:HDJKu9G5nv0DxuM’, ‘value’: -1, ‘type’: ‘digital_actuator’, ‘name’: ‘Relay Switch’, ‘unit’: ‘d’}]
2019-07-10 11:07:39 - myDevices - INFO - Send changed data: [{‘sys:ram;usage’: 242053120}]
2019-07-10 11:07:52 - myDevices - INFO - Sensors info: [{‘channel’: ‘dev:HDJKu9G5nv0DxuM’, ‘value’: -1, ‘type’: ‘digital_actuator’, ‘name’: ‘Relay Switch’, ‘unit’: ‘d’}]
2019-07-10 11:07:54 - myDevices - INFO - Send changed data: [{‘sys:cpu;load’: 2.0}, {‘sys:ram;usage’: 242044928}, {‘sys:storage:/;usage’: 5309984768}]
login as: pi
^Z
[1]+ Stopped tail
2019-07-10 11:08:07 - myDevices - INFO - Sensors info: [{‘channel’: ‘dev:HDJKu9G5nv0DxuM’, ‘value’: -1, ‘type’: ‘digital_actuator’, ‘name’: ‘Relay Switch’, ‘unit’: ‘d’}]
2019-07-10 11:08:09 - myDevices - INFO - Send changed data: [{‘sys:cpu;load’: 16.1}, {‘sys:cpu;temp’: 40.622}, {‘sys:ram;usage’: 242044928}, {‘sys:storage:/;usage’: 5309988864}, {‘sys:net;ip’: ‘192.168.1.43’}, {‘sys:net;speedtest’: 2.3004317910471794}, {‘dev:HDJKu9G5nv0DxuM’: -1}] + sys:gpio
2019-07-10 11:08:22 - myDevices - INFO - Sensors info: [{‘channel’: ‘dev:HDJKu9G5nv0DxuM’, ‘value’: -1, ‘type’: ‘digital_actuator’, ‘name’: ‘Relay Switch’, ‘unit’: ‘d’}]
2019-07-10 11:08:24 - myDevices - INFO - Send changed data: [{‘sys:cpu;load’: 30.2}, {‘sys:ram;usage’: 242032640}]
2019-07-10 11:08:37 - myDevices - INFO - Sensors info: [{‘channel’: ‘dev:HDJKu9G5nv0DxuM’, ‘value’: -1, ‘type’: ‘digital_actuator’, ‘name’: ‘Relay Switch’, ‘unit’: ‘d’}]
2019-07-10 11:08:39 - myDevices - INFO - Send changed data: [{‘sys:cpu;load’: 0.0}, {‘sys:ram;usage’: 242028544}, {‘sys:storage:/;usage’: 5309992960}]
2019-07-10 11:08:52 - myDevices - INFO - Sensors info: [{‘channel’: ‘dev:HDJKu9G5nv0DxuM’, ‘value’: -1, ‘type’: ‘digital_actuator’, ‘name’: ‘Relay Switch’, ‘unit’: ‘d’}]
2019-07-10 11:08:54 - myDevices - INFO - Send changed data: [{‘sys:cpu;temp’: 40.084}, {‘sys:ram;usage’: 242024448}]
2019-07-10 11:09:07 - myDevices - INFO - Sensors info: [{‘channel’: ‘dev:HDJKu9G5nv0DxuM’, ‘value’: -1, ‘type’: ‘digital_actuator’, ‘name’: ‘Relay Switch’, ‘unit’: ‘d’}]
2019-07-10 11:09:09 - myDevices - INFO - Send changed data: [{‘sys:cpu;load’: 1.0}, {‘sys:cpu;temp’: 40.622}, {‘sys:ram;usage’: 242016256}, {‘sys:storage:/;usage’: 5309997056}, {‘sys:net;ip’: ‘192.168.1.43’}, {‘sys:net;speedtest’: 2.3004317910471794}, {‘dev:HDJKu9G5nv0DxuM’: -1}] + sys:gpio
