Any TTN LoRa static location device -
Web -
ON adding a new TTN LoRa device and entering the Location
I am trying to type “Australia”
It comes up with any and every USA address that do not have australia in it.
But if I hit backspace once, it then offers Australia in the drop down selection
Doesnt matter if I type austr, austral, australi, hitting backspace onec triggers the correct drop down selection
