pi@raspberrypi:~/python $ cat tempsensor.py
import time
import Adafruit_DHT
time.sleep(60) #Sleep to allow wireless to connect before starting MQTT
MQTT_USERNAME = “”
MQTT_PASSWORD = “”
MQTT_CLIENT_ID = “”
client = cayenne.CayenneMQTTClient()
timestamp = 0
while True:
client.loop()
humidity11, temp11 = Adafruit_DHT.read_retry(11, 4) #11 is the sensor type, 4 is the GPIO pin number that DATA wire is connected to
if temp11 is not None:
client.virtualWrite(3, temp11, cayenne.TYPE_TEMPERATURE, cayenne.UNIT_CELSIUS)
if humidity11 is not None:
client.virtualWrite(4, humidity11, cayenne.TYPE_RELATIVE_HUMIDITY, cayenne.UNIT_PERCENT)
timestamp = time.time()
pi@raspberrypi:~/python $ cat tempsensor2.py
import time
import Adafruit_DHT
MQTT_USERNAME = “”
MQTT_PASSWORD = “”
MQTT_CLIENT_ID = “”
timestamp = 0
while True:
client.loop()
humidity11, temp11 = Adafruit_DHT.read_retry(11, 17) #11 is the sensor type, 17 is the GPIO pin number that DATA wire is connected to
client.virtualWrite(5, temp11, cayenne.TYPE_TEMPERATURE, cayenne.UNIT_CELSIUS)
client.virtualWrite(6, humidity11, cayenne.TYPE_RELATIVE_HUMIDITY, cayenne.UNIT_PERCENT)
