Error compiling with CAYENNE_IN(1)
Hello. Please help me.
I insert in my sketch file
CAYENNE_IN(1)
and have compiling error
MyWeatherStation-PxMatrix-Cayenne:149:20: error: variable or field ‘InputHandler1’ declared void
MyWeatherStation-PxMatrix-Cayenne:149:20: error: ‘Request’ was not declared in this scope
MyWeatherStation-PxMatrix-Cayenne:149:29: error: ‘request’ was not declared in this scope
MyWeatherStation-PxMatrix-Cayenne:149:38: error: ‘CayenneMessage’ was not declared in this scope
MyWeatherStation-PxMatrix-Cayenne:149:54: error: ‘getValue’ was not declared in this scope
if i compiling sample file esp32, this compiling with out error
you can replace it with:
CAYENNE_IN(1)
if you want to read the value on the channel 1
the same error (
can you share the entire code.
MyWeatherStation-PxMatrix-Cayenne.txt (25.6 KB) utf8rus.txt (742 Bytes)
This is my sketch
Sorry.I do not understand. But i copy past my sketch in new by block. And now compilling with out error.
Thanks all.
glad to hear it is working now.
