Error sending data from Kerlink SPN v2
Hello, try to sending data from Globalsat LT-100 using Kerlink iStation and SPN V2 into Cayenne but i get some error result.
From the gateway log, i can see the error is:
RHTTP ERR Unable to send Rx data to URL https://lora.mydevices.com/v1/networks/kerlink/uplink: SSL connect error
I have read and follow guide on this page but looks like it is a guide to work with Kerlink SPN v1
https://developers.mydevices.com/cayenne/docs/lora/#lora-kerlink-network-setup-gateway-device
As there is no HTTP Transmitter on SPN v2, i use Remote HTTP REST and putting this on the settings
Use HTTPS: True
Host: lora.mydevices.com
Port: 443
Path: /v1/networks/kerlink/uplink
Any idea how to solve this issue?
Here is some screenshot that i think would help to explain the problem
SPN HTTP Settings
Error Log
Thank You
can you try a reboot of the gateway.
Yes, but it still showing the same error. I’ve been trying it for several days actually.
