Hi *
Does Cayenne.loop on ESP32 really take 1 second?
When I watch the millis before and after it’s quite exactly 1000. I’m concerned about the response time of other tasks in the main loop.
Best regards
Peter
Hi *
Best regards
Peter
you can make Cayenne.loop() to execute at a large interval between each loop using Cayenne.loop(10)
Thank you!
I assume the value 10 serves as example for seconds, right? In the meantime I worked around running Cayenne.loop() at 0.5Hz rate (once every second second). Would there be any difference to Cayenne.loop(2) ?
Happy New Year!
Peter
Happy new year @PeterPi
10 serves as times in millis that is 10,000 millis.
the loop will run every 2 seconds.
Confusing but thanks, I’ll just try.
