Hi team cayenne.
my project is simple, I am trying to connect to the wireless network, but the connection does not respond.
attached image of the code and serial viewer.,
Use a esp8266 01
Thank you
Hi team cayenne.
Use a esp8266 01
Thank you
that either means you password is wrong or some issue with router which is why the esp is nt connecting to wifi.
I already connected, but I had to rest many times the pin rst. what do you think is the problem? My network is with a good signal.
Thanks again
I do see some garbage value in the screen shot of your serial monitor. Can you try a basic esp8266 code to connect to wifi and see if the issue is still present .
can you try powering the ESP from a different 3.3V power supply.
Thank you
increase the voltage to 4.9 and it worked.
thank you
