Hello !!! We are final year students from Don Bosco College of engineering Fatorda, Goa, India.
Our Project is field Automation, where in we control irrigation via one the algorithm which we have developed.
The PROBLEM !!! Which we are encountering on Cayenne I am Explaining it up next:
We are Keeping One AUTOMODE BUTTON on the Cayenne Dashboard.
If that AUTOMODE BUTTON is PRESSED (state indicating Automode is on) Then Our Automatic Irrigation control Algorithm will run and will automatically Irrigate (Will Put ON the solonoid valve ie. water reaches the field ) the field at required times (Fully Automatic NO MANUAL interruption).
W.r.t Point 2 we are doing one more thing simultaneously we are displaying the state also of the Water Valve Whether it is ON or OFF only applicable for Auto-mode algorithm, For that we are using state Button named STATE
Now when That AUTOMODE BUTTON is NOT PRESSED we will Irrigate the Field Manually Ie There will be one more Button On the Dashboard Named MANUAL CONTROL BUTTON and if that Button is pressed that Valve will be ON (Water reaches Plant) and if that Button is released Valve will be OFF (Water does not reaches plant)
Considering point 4 and 3 Manual state will not be displayed eg:
lets say ;
if we are in Manual Mode ie AUTOMODE Button is NOT PRESSED
and using MANUAL CONTROL BUTTON We are putting off the valve
but According to the Field Automation Algorithm Which is running simultaneosly if the valve has to ON then it will still display the state of the valve on STATE Button ie ON that does not clash with MANUAL OFF
SO This is our code: BUT IT GIVES ERROR AND WE FOUND OUT ALL POSSIBLE WAYS TO SOLVE OUR PROBLEMS
//#define CAYENNE_DEBUG
#include <CayenneMQTTESP32.h>
char ssid[] = "huwai";
char wifiPassword[] = "12345678";
char username[] = "";
char password[] = "";
char clientID[] = "";
pinMode(2, OUTPUT);
CAYENNE_IN(0) // AUTO BUTTON CHANNEL IS 0
if(getValue.asInt()==1)
while(getValue.asInt()==1)
digitalWrite(2, HIGH); // turn the LED on (HIGH is the voltage level)
CAYENNE_OUT(2) //STATE BUTTON MADE ACTIVE
Cayenne.virtualWrite(2, 1);
delay(1000); // wait for a second
digitalWrite(2, LOW); // turn the LED off by making the voltage LOW
CAYENNE_OUT(2) //STATE BUTTON MADE DE ACTIVE
Cayenne.virtualWrite(2, 0);
delay(1000);
else
CAYENNE_IN(1) // MAN CONTROL BUTTON
digitalWrite(2, getValue.asInt());
