HT-M00 Dual Channel LoRa Gateway
Good new for the HT-M00,it is a low-cost dual-channel gateway.It is located to smart family LoRa applications that work with less than 30PCS LoRa nodes. This gateway is based on two SX1276 chips driven by ESP32. We wrote a software mixer (also called a baseband simulation program) to make it possible to achieve 125KHz SF7~SF12 spreading factor monitoring. If you need to buythis, don’t forget to read this! [ HT-M00 Dual Channel LoRa Gateway – leapIOT)https://leapiot.cc/product/ht-m00/…
coupon code (NDQ5SGHF)
I’ve listed all the tutorials in this article !:slightly_smiling_face:
